Zanussi ZWX1605W all LEDs flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanussi ZWX1605W all LEDs flashing
  • #84715
    IoanP
    Hi, I just changed the draining hose for my washer, during the process had to lay it on one side as the only access for doing it is a door on the bottom of the washer, after finishing tried to put it on but all the LEDs start flashing at once, and no matter what I do, will not respond to any button I press.
    Can anyone help me, please?
    Thank you.
    #426542
    Seamy
    Re: Zanussi ZWX1605W all LEDs flashing
    Likely that either you let water get onto the electronic p.c.b or dislodged some of the wiring.
    All I can advise is that you switch it off, on & off again to see if it clears.
    Access is by removing the rear half, for the next time you try it.
