ZANUSSI ZX56/4 fridge not cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum ZANUSSI ZX56/4 fridge not cooling
  • #22368
    smudge666
    The fridge part is not cooling, and when turning up to maximum cool it makes absolutely no difference.
    the freezer seems to be working properly at the moment.
    the compressor is quite hot.
    :rolls:
    thanks
    #194682
    brizyuk
    Re: ZANUSSI ZX56/4 fridge not cooling
    I’ve had a similar problem with my frost free zanussi zbf249w model.
    No cooling in fridge & red hot compressor
    In my case in the rear of the freezer section were 4 screws. On removing these screws remove the plastic cover.
    behind the cover is what i presume is the evaporator & a fan which is used to circulate cold air up into the fridge section & around the freezer.
    My evaporator was heavily frozen so i switched off & defrosted it with an hair Dryer. The fan appeared to be running ok so I can’t understand why the air wasn’t flowing around the fridge section, unless it started running once the plastic cover was removed.
    Mine has been ok for a few days but I suspect their maybe a reason for the unit not defrosting etc.
    Worth a try as a possible short term fix…..Don’t use anything sharp when trying to defrost otherwise you’ll risk serious damage to the freezer.
    #194683
    EL
    Hi there, I have the same model and it is not cooling all together F&F… But the compressor is running & noisy..Have you been able to fix it?. any luck?
    #194684
    the problem that you will have is somewhere within the defrost cycle.
    either the heater,overload or defrost timer has failed.
    this then causes the evaperator to ice and freeze over which in turn restricts the airflow though the evaperator which allows the cold air to go into the fridge compartment.
    this will normally be shown by the fridge starting not to cool then it will eventually lead to the freezer starting to defrost.
    defrosting the unit will rescue the operation for a few days/week but it will need to be investigated and repaired.
    Bryan
    #194685
    EL
    I switched it off totally for a few days. cleared the fridge, and switch it on for a day, but the cool still doesn’t come back. I will look for professional then..Thanks for your advice.
    Cheers
    EL
