Zanussi ZX56/4W Fridge freezer problem
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Zanussi ZX56/4W Fridge freezer problem
  • #24011
    Tonyfj
    The freezer is working fine but the fridge is not cooling. I can hear what sounds like the compressor noise all the time. Any ideas what the problem is? Thanks Tony
    #200216
    Fairdeal
    Re: Zanussi ZX56/4W Fridge freezer problem
    Is it a frost free fridge freezer?
    if it is then you probably have to switch it off for 24 hrs and then switch it back it on.
    If not then usually gas leaks in the fridges.I have seen Zanussi fridges just over a year’s old and same problem with them.
    Reason why this normaly happens is because of the internal cooling system.
    Regards
    #200217
    Tonyfj
    Thanks for info. It is a frost free model. Problem was a faulty defrost timer. Tony
