zanussi zx77/5si fridge freezer alarm
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries zanussi zx77/5si fridge freezer alarm
  • #61333
    crockett
    Hi I have zanussi zx77/5si fridge freezer that is working ok but every 5 to 6 weeks the alarm goes off and when reset its grand for another 5 to 6 weeks then the same thing happens again, the condensor has been cleaned out properly, it seems a nuisance problem more than anything else, any help will be greatly appreciated, thanks.
    #345707
    martinm
    Re: zanussi zx77/5si fridge freezer alarm
    the last time i seen this problem with one of these it turned out to be a slightly weak compressor. i.e.- enough to keep it frozen but the pcb times the lenghth of time it takes to get back to temp after defrost and if it longer than the preset then it gives alarm
    #345708
    crockett
    martinm wrote:the last time i seen this problem with one of these it turned out to be a slightly weak compressor. i.e.- enough to keep it frozen but the pcb times the lenghth of time it takes to get back to temp after defrost and if it longer than the preset then it gives alarm
    thanks martinm for your answer is there any way i can bypass or reset pcb and or disconnect alarm etc because its not really worth replacing compressor and re charging the unit or will they just have to put up with the inconvienience of the alarm going off every so often.
    #345709
    martinm
    I think as long as its keeping temp they only have to press alarm off when it happens.
    #345710
    crockett
    thanks again martinm much appreciated.
