Zanussi ZX77 Fridge Freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Zanussi ZX77 Fridge Freezer
  • #7904
    The fridge compartment has stopped cooling and the Freezer is OK
    Any clues on the problem ? and how to diagnose
    Many thanks
    #125836
    8 different variants on this one – please post up the “pnc” number as well. This will give the fridge lads a better chance of helping you.
    Dave_Conway
    Re: Zanussi ZX77 Fridge Freezer
    That isn’t the full model number I’m afraid.
    It will be ZX77/??
    We’ll assume though that it is a frost free unit, in which case there is an excessive ice build up in the freezer by the sound of it.
    This could be down to either a defrost problem (engineer required) or the freezer door was left open accidently.
    Either way, you can check by emptying and switching off for 24 hours with the doors open to defrost it completely then try again. IF it carries on working then problem solved, if there is an underlying problem though it will ice up again in either a few days or a few weeks giving the same symptoms.
    #125838
    The Full model No is ZX79/5SI
    Other numbers are
    928405921
    8406953
    #125839
    Dave_Conway
    In that case, please follow my previous advise and defrost it as it’s a frost free unit 😀
    #125840
    Thanks.
    All OK now
    So What happens and will it occur every so often ?
    #125841
    Dave_Conway
    Possibly, if it does please come back and check here as you’ll need an engineer to rectify the underlying cause.
    #125842
    Guess What, Problem Back
    Is there a fix ?
    #125843
    Dave_Conway
    There will be a fix yes, but it depends on the fault as it could be one of a few things causing this to be honest.
    Checking the directories and repairs@ for an engineer may be your best option.
    #125844
    Is there a fix ?
    #125845
    skankz
    this model along with with some otherfrost free hade a problem with the defrost drain valve. it is a small rubber tube like the end of a baloon which is on the exit of the drain above the compressor. it would stick shuth and not let water through and ice would then form under the evap and if left long enough wold cut air to fridge.
    remove valve and clean. ice will probebly take more than 24 hrs to defrost as it is 2.5 inchs thich and 6 inchs high behing an insulated panel. I would sujest removing rear panel to aid defrosting, if you have steam cleaner or wall paper striper this would speed it up as steam melts ice fast. if the ice is in the evap only you have a timer or heater circuit problem. my bet would be the timer. good luck.
