Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Zanussi ZX79/5SI FRIDGE PROBLEMS
- This topic has 7 replies, 6 voices, and was last updated 18 years, 9 months ago by
shiny.
July 3, 2007 at 8:39 pm #28698
shiny
Participanthello
wonder if anyone could help ?
Its all been said before, I am sure but any ideas for a fridge / freezer frost free where the fridge has stopped chilling except when you defrost it, when it works fine again for 10 days or so ???Ideas ?????
evaporator thermistor ??
thermostat ??I appreciate that there could be a number of plausible reasons but any ideas would be appreciated !!
Any idea on part nos for the above ??
Serial no is 21200224
Type no is 8406953
Prod no is 928405921Thanks
ShinyJuly 5, 2007 at 11:27 pm #219640helo_75
Participantdefrost timer
everytime
cant get the part number, cos procorners down right now
im sure someone here can get you the pasrt number
oh, and its located in the little white box at the back, near the compressor!!”
plug out if your gonna mess plz
July 15, 2007 at 3:03 pm #219641tdc
ParticipantRe: Zanussi ZX79/5SI FRIDGE PROBLEMS
SIR, YOUR NOT AN LG SPECIALIST AS WELL BY ANY CHANCE ?
July 15, 2007 at 3:05 pm #219642helo_75
Participant??
July 15, 2007 at 3:06 pm #219643Simon46
Regarding fan motor post.
http://www.ukwhitegoods.co.uk/modules.p … 463#143463
S.January 26, 2008 at 2:41 pm #219644Bottle
Having the same sort of problem – fridge now sitting at 20 degrees, all warning lights flashing and have been even when the temp was correct. The alarm also goes off regularly, even at low temp.
What is this defrost timer thing for?
February 19, 2008 at 12:35 pm #219645TheSpinDoctor
This model has no defrost timer. The defrost cycle is swiched on & off by the control board. The most likely cause is either the evaporator or drain heaters going open circuit. Another thing could be an out of calibration evaporator or air sensor which the board doesn’t recognise as a fault unlike if they go open or short circuit. Best thing to do is unplug the appliance & test for continuity of both heaters. If they check out, it is probably the sensor.
Let me know how you get on.
February 19, 2008 at 5:57 pm #219646helo_75
Participantso its the model with the ntc?
thats the usual culprit… my mistake, sorry
