Zanussi ZX99/5 warm freezer, fridge part is fine
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Zanussi ZX99/5 warm freezer, fridge part is fine
  • #22025
    cenda
    I have ZX99/5SI (SN:9284059333230184) which after some time of not being used got switched on and it is not cooling in freezer cabinet to -18C, but just -3C. Fridge cabinet has stable 4C which is good. Compresor is running quietly, time to time fans get turned on. I have cleaned it (including condenser) before we turn in on. I gave it more then 24h to settle down temperatures, but there is no change. I found similar problems elswhere, but no solution. Can you help please.
    Cheers
    George
    #193452
    Re: Zanussi ZX99/5 warm freezer, fridge part is fine
    have you checked the condensor inside the freezer to make sure there is an even spread of frost across it, could be blocked or short of gas.
    #193453
    whitevanman
    kandl-appliancerepair wrote: the condensor inside the freezer
    the evaporator this is called 😕
    #193454
    😳 I gets confused easily 😳
