Zanussi zx99/5si
  • #37504
    nolights
    Hi can any one help me , where can i find the switch that operates the lights in the fridge , bulbs have been replaced , the fridge works but no lights..
    thanks
    Nolights
    #255335
    helo_75
    its on a magnet on the pcb isnt it?
    generally, if youve changed the bulb, and it still aint working, itll need a pcb
    #255336
    nolights
    Re: Zanussi zx99/5si
    many thanks for the reply , i will have a look and update everyone
    paul
    #255337
    nolights
    I have taken the pcb out, checked the magnetic reed switch that works on it turns the dial lighting off and on , looking at the pcb the power tracks for the interior lights go fron the connector on the righthand side of the pcb to the left via two link wires across the pcb to the large connector on the pcb , which then goes off into the top of the fridge via a ribbon cable . the voltagew across the two link wires is 53v ac . any ideas where the ribbon cable goes too . Has anyone got a circuit diagram for this beast please.
    regards
    nolights ..paul
    #255338
    helo_75
    theres another pcb on the back, near the compressor
    thats where the ribbon cable goes to, i suspect
    #255339
    nolights
    many thanks , will have a look over the weekend
    #255340
    nolights
    it looks like th3 has blown apart on the pcb this is surface mount , i cannot identify the component as not enough left of it ,
    so it seems like a new pcb OUCH
    #255341
    helo_75
    harsh i know, but thats the way things are going im afraid 🙁
    #255342
    nolights
    hi
    Has anyone got an old main pcb , i am trying to repair my pcb i need to now the componet TH3 , which is near the ribbon connector or can you send me the old pcb if this part is still intact i will pay postage costs,
    #255343
    cockney steve
    Try a good electronics engineer(try a one-man tv&radio repairer) -explain what the board does, he’ll possibly know what sort of device it is, and an acceptable substitute.
    Whether it’s cost-effective, is another issue!
