The washing is coming out very creased and sometimes warm/hot. Checked on 50deg cycle. Water on loads cold. After wash it pumps out extremely hot. Next two fills are progressively colder. Last pump out has a short period which is hot and then it is cold. Have changed the thrmostats on the drum. Any ideas why it is suddenly coming out very creased?
worth checking if the hoses on the back are the correct way round if it is a hot and cold fill machine… rinsing in hot water will cause this . also check the water is draining away sufficiently from the wash cycle
