Re: ZanussiZBD904W Microwave/Fan oven
you need to know if the microwave is firing up put a test meter on the transformer primary (240v side ) and see if you get mains when you activate. no use looking at mag and the like if you got no power. you can disconnect the secondary so you dont have high voltage floating about
yes diode needs at least 9v to be able to show it works ok
hope this should move you forward get back to me if you want more input
dave
