Zanusssi Aquacycle 1000 SPIN PROBLEM
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Zanusssi Aquacycle 1000 SPIN PROBLEM
  • #87112
    fixitok
    Zanusssi Aquacycle 1000 Model F1045 W
    My washing machine will not execute a long spin (“G” on program control)
    Drum rotates freely, stops & starts intermittently but will not do a long spin
    Any help much appreciated
    #433993
    Re: Zanusssi Aquacycle 1000 SPIN PROBLEM
    if i am right you have the older type of mechanical timer ( ie you turn a knob to det the programme and you can hear the switches clicking as you do)
    when you set a spin programme the machine seem to try to speed up into spin but fails each time
    if so its a failure of the power supply that feeds the electronics on the timer
    faily easy fix for a professional thats had it before
    thats if i am right
    fixitok
    Dave, thanks for diagnosis, yes it has the rotary control to select programmes etc.
    Any data on power supply-voltage etc & I would check with meter.
    Reg Pat
    #433995
    dont know voltages but power supply is designed to drop the voltage from 230 to under 50 ( dont know exact voltage). in this unit they use a 1uF (i think ) capacitor as a dropper. As these age the voltage on the board falls and the unit starts to fail
