What voltage is the fan getting?
What is the PNC number of the oven as there are several versions of that model number and not all have control boards.
If you can turn the fan freely by hand and it is getting 240v to it then I would say that it has a shorted turn on the coil, you can’t measure it on an ohm meter as it will have such a small effect on the resistance but it destroys the magnetic field and stops it running. The easiest way to check/confirm if you are not sure is to connect it directly to power with a fly lead and see if it spins properly – I suspect it won’t.
Double check your PNC as it doesn’t show up.
