Hi got this washer pnc no: 914791167/00 turn it on to any program and the end wash light flashes and beeps. Nothing else happens tried to go into fault diagnosis leds flash then onto next stage and all 5 leds in a row light up. Thought it might be a door lock but did not have one on the van to try. Any ideas thanks.
hi have loads of problems with these. you have tried to go into diagnostic, if you cant get in it is probably knackered, most common fault is short circuit drain pump blowing board, but have had door lock s/c and motors/c both taking out the board, there is no protection for board.
