Re: ZDC37200W Synthetic Cycle overheating
Thank you Dave, I’ve found it now. Am I correct in assuming that this thermostat is probably the culprit and are there any tests I can do to confirm? I’ve checked continuity and that is ok but then that is what I would expect. I’m assuming that it doesn’t switch but then without taking the control board out I can’t find a point that I can monitor. Is it actually a thermistor and if so what should be it’s default resistance value?
Many thanks,
Wizz
Wizz
