Zdh8333w heat pump drier
  • #95316
    machineman
    PROD 91609769000
    Any ideas on why this doesn’t heat
    #459994
    not sure how much experience you have with these dryers but there are no heaters as such so don’t expect the kind of temperatures you get with a normal dryer.
    Is the compressor running and if yes is the evaporator getting cold ?
    think if this more like a de-humidifier in a case
    machineman
    so all down to compressor or gas in system
    #459996
    only heat in the unit is the recycled heat from the compressor so when its working is more like luke warm and that’s no quick
    I would put wet clothes in it and check to see if the compressor is running
    can prob get a service manual if you get stuck but would need an email address to send it too
    machineman
    that would be great davepricedar@btinternet.com
