ZDT2100FA dishwasher
Home Forums Trade Technical & Spare Parts Forums ZDT2100FA dishwasher
  • #103568
    HotDog
    This dishwasher is draining constantly there is no water in the base and I have checked the float switch is working ok not sure with Zanussi as to the issue I’m sure it probably a common fault
    #493744
    well your model is incomplete and if you miss FA off the end i get 29 machines
    my best guess would be a board triac short but with correct model can look at proper tech
    HotDog
    Yes it would help with the pnc 539 135 02 apologies
    #493746
    HotDog
    I’ll get this right if I stop rushing pnc 911 539 135 02 s-No62229525
    #493747
    ok pump is fed live and gets a neutral in one of 2 ways
    1 through the overflow sw
    2 from the board when pump triac is operated
    first thing i would do is disconnect the overflow sw just to eliminate and try it
    assume the house has an RCD on the mains power so if fault was caused by a neutral short the trip would blow but double check not only for a trip but neutral shorts
    after that its going to probably be faulty triac. they often half fail and give 110 volts which you can check with a multimeter across pump
    you can also check for slugs as the little devils get everywhere
    if its a triac they can be swapped if you can solder small items
    HotDog
    Brilliant thanks Dave
