ZKI245 Dryer problems
  • #66032
    johnnyj
    Can anybody help me with this fault when on dry the machine tumlbles for a couple of minutes then the dryer fan comes on it will then count down with no heat and go to end after approx 10 mins like it is just doing tumble cool, no error code is shown, i have checked the stats and drier heaters and meggered but cannot find anything, i was wondering if it may be dryer ntc duff or faulty board, any help on this one would be welocome cheers JJ
    #362811
    bigchrisoioi
    Re: ZKI245 Dryer problems
    check the error code in diagnostics…..E10 willbe faulty 3 way valve, E73 will be broken NTC cables….E22 will be blocked condensor…these are the most likely ones
    #362812
    johnnyj
    Thing is it isnt coming up with an error code, this is what has got me stumped, JJ
    #362813
    bigchrisoioi
    it will hide it…..put machine into diagnostics to find it
    #362814
    johnnyj
    Sorry Chris i keep forgetting that with these it has an E72 fault i assume is dryer ntc as E71 is the wash ntc, does anybody know the part n/o for it thanks jj
