Znaussi ZOB142X oven issue
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Znaussi ZOB142X oven issue
  • #85083
    storm123
    Hello,
    I recently changed out the element on my built in Zanussi ZOB142x oven due to the electric constantly tripping when it was used.
    The new element has resolved that issue.
    A new issue has now come to light in that the oven light is constantly on whilst the fan is equally constantly blowing. I have resorted to powering it off from the wall socket for the time being.
    Any ideas what might be causing this issue and what approximate cost would be to put right?
    Thank you
    #427660
    Re: Znaussi ZOB142X oven issue
    Could be the main function switch that’s the problem, have a look and see if anything looks burnt or broken. Assuming of course that the wiring hasn’t been altered for any reason.
    I’d need the PNC number to give you the correct one if required, there’s three versions of that oven.
    storm123
    Re: Zanussi ZOB142X oven issue
    Thanks for that.
    I’ll open it up later tonight to look at it.
    Fortunately I know the PNC of the oven which is 949713155-00
    I’m had it from new for 3 years so hopefully wiring is sound.
    Just trying to work out if I’m better off replacing it altogether.
    Thanks again kwatt.
    #427662
    It’s this one in that version:
    http://shop.ukwhitegoods.co.uk/35819800 … ion-switch
    Let’s just say, they’ve been known to fail.
