ZSF6160 powerswitch connectors
Home Forums Public Support Forums Help And Support Dishwasher Help Forum ZSF6160 powerswitch connectors
  • #81959
    kevindontenville
    Just putting a Zanussi ZSF6160 dishwasher back togther and was plugging back in the front panel connectors after a board repair and heater replacement and realised I missed recording the powerswitch connections.
    I dont think it falls into prohibited request of ‘re-wiring’ per se, so wondered how I can confirm the connector to plug pinout?
    I have the 6 connecters on the powerswitch and 5 connectors with wires to plug on.
    Tabs:
    “rear”
    1 2
    3 4
    5 6
    ‘Button’
    I have 5 wires:
    Black wire (unshielded connector) from lamp unit
    Blue wire (unshielded connector)
    Orange wire (white connector shroud)
    Blue wire (white connector shroud)
    Brown wire (white connector shroud)
    Can anyone indicate what the pinout should be?
    Usually I would record such obvious things but on this occasion it seems I was more concerned with getting the board repaired and parts and after several delays my short term memory is not helping!
    I could make a fair stab at it but I would like to make sure I don’t screw it up further!
    Kevin
    #418276
    Re: ZSF6160 powerswitch connectors
    Best I could do…..
    #418277
    kevindontenville
    OK, thanks that will be enough to work through. Thanks very much, especially on a BH weekend, wet though it is!
    K
