Confused of Preston here:?
Been to above yesterday fault, originally no drain then A5 fill time out.
Tested machine yo hear motor low pressure, normal pressure in bursts. Opened door to check (yes, with latch set 🙂 ) and only lower arm had any movement. Ordered motor.
Later in day went to a DE6965 which is giving the old no fill fun (ordered iwms) and noticed on test a similar thing. Set quickwash and motor fires up after detergent disp. opens.
Am I being dense but I can’t find anything in the manual about this.
Tony C
