Re: Zunussi ZWF 1437W
Have seen this pipe block quite often, it is the pipe for what Zanussi refer to as the ‘jetsystem’. Funnily enough it is often overlooked when diagnosing so well done there. As for removal, relase the door boot from the front of the machine only. The clamp there can then be removed with a flat bladed screwdriver. Be careful not to slip! With the top off of the machine (mains off ofcourse) and water removed via filter, thread out hose and roll/agitate or just replace. Re-fit with plyers, it will click back together. Dont forget to check tub vent hose at top of drum also. If fitted, its the one that links to the dispenser side.
Scott.
