Re: ZWD 16270W Cleaning Condenser
chris211 wrote:they are a right pain you need to remove the front panel,the dryer duct, blower unit hose tub to condenser all fun and will take time
I’ve not had to remove the front panel in order to remove the condenser. 😕
Back off, top off, remove blower unit, NTC in bottom hose, bottom hose from tub, drain hose from pump, water inlet tube, remove drain hose from rear and unclip drain hose coupling in back panel then wiggle condenser unit up and out! First ones always a cow after a couple it gets easier.
Crap design all the same. :rolls:
