Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zwd 16581 washer dryer just shos error in display
- This topic has 6 replies, 4 voices, and was last updated 15 years, 11 months ago by
delta01.
April 29, 2010 at 2:35 pm #54291
delta01
Participanthi this machine just shows error and doesnt seem to want to go into diagnostics suspect usual pcb , allso noticed its asealed tub variety i think zanusie are now worse than hopmerloni i tried door lock and checked al usuall things ie pumps heater motor even visual inspection of control panels its only 2/3 yrs old any help appreciated
April 29, 2010 at 3:50 pm #319113Martin
ParticipantRe: zwd 16581 washer dryer just shos error in display
Module stuffed but also you need to find the cause? Interloc? Motor? Heater? are main suspects. Personally I would offer the customer a fitting funeral service with all the trimmings attached for a modest extra fee of course. 😉
April 29, 2010 at 5:03 pm #319114delta01
my sentiments entirely will offer them a quality machineas the risk of bearing failure is high due to it being so old …… ie lg, daewoo, ise10
thanks for reply martinApril 30, 2010 at 1:10 pm #319115rub
dont scrap it just yet the most common fault by far are the dryer elements going short circuit this scrambles electronics. Easeist way of finding out jst disconnect the element if it works normally hey presto.
Hope this helpsRub
April 30, 2010 at 5:49 pm #319116delta01
thanks rub will look at that
May 5, 2010 at 8:29 pm #319117gandh1
How did you get on with this? any info?
delta01 wrote:as the risk of bearing failure is high due to it being so old
it cant be all of about 2 years old at most!!!
delta01 wrote:quality machine
delta01 wrote:daewoo
:rolls:
May 5, 2010 at 10:20 pm #319118delta01
it wasnt dryer heaters assumed module faulty as tested all components customer happy to purchase ise 10 ,zanusie and other manufacturers will reap a heavy loss of sales due to their short sighted and greedy attempts to force customers to insure or replace machines by making them uneconomical repairs
