zwd12270w not starting Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zwd12270w not starting This topic has 4 replies, 3 voices, and was last updated 15 years ago by funbobby. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts March 22, 2011 at 9:00 am #61801 funbobbyParticipant strange one this, when you press start door lock light goes solid but then you just get a humming noise from what sounds like the valves or mains filter? checked insulation on both elements and swapped interlock but no joy, any thoughts? March 22, 2011 at 9:15 am #347669 CriscoldParticipant Re: zwd12270w not starting Can you get into diagnostics ? Colin March 22, 2011 at 12:14 pm #347670 funbobbyParticipant Re: zwd12270w not starting how do i do that? March 22, 2011 at 1:02 pm #347671 MartinParticipant Re: zwd12270w not starting funbobby wrote:, any thoughts? First thing it does after door locks is pump. Could the noise you hear be the pump? See error code thread or UKW Bible or TDS disk for Zanussi diagnostics access by the way. March 22, 2011 at 4:14 pm #347672 funbobbyParticipant Re: zwd12270w not starting ok will look into diagnostics, def not pump it was coming from top left as your facing it. Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
