zwd12270w1 not condensing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zwd12270w1 not condensing
  • #82353
    gramp
    zwd12270w1 914604028/02
    The problem is that the dryer in not condensing.
    When you start a drying cycle the pump works and the solenoid condensing valve works but once the fan and heater start the the solenoid valve and pump stop and don`t come back on again .Steaming the clothes .
    Running a dryer test cycle everything works .
    Any ideas guys . Thanks In advance .
    #419605
    Re: zwd12270w1 not condensing
    Fluff blocking the lower part of the condenser?
    #419606
    gramp
    Martin. Checked that clean like new
    #419607
    If there is an earth leak on the dryer element then odd faults like this are likely to happen.
    #419608
    gramp
    Martin . Will check that tomorrow was going to try changing the dryer module too and see how it goes from there
    #419609
    gramp
    Martin i checked the heater and it was fine so replaced the dryer module and that seems to have cured the problem. Thanks for your help.
