zwd1471s spider won`t come out of its web!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum zwd1471s spider won`t come out of its web!
  • #60262
    stryder
    still having trouble, the spider bolts came out easy and they`re all like new so i can re-use. only problem the spider still won`t seperate from the inner metal drum. the holes for the bollts in the metal drum have been pressed inward by the taper below the bolt heads . they protrude slightly into the threads on the spider stopping me from sliding it out of the lip on the drum. anyone got any ideas how i can get past this latest obstacle?
    #341566
    quickwash
    Re: zwd1471s spider won`t come out of its web!
    Hi stryder,
    Just a little thing to note which may help all round 😀
    It would be better to continue your posts (on the same subject) on the orginal thread, otherwise the ‘guys’ have to search for your original thread to discover from what you are ‘still having trouble’ :?. Plus if you use the same one all the time, those who have helped you get notified of any more posts on the same thread, so ‘the guys’ get to see them, and hopefully reply to you, much quicker 😀
    best wishes and good luck with the repair, keep us posted (on the same thread hopefully 😉 )
    quickwash :plug:
    PS – the new posts, even on old threads, move that thread to the ‘top of the pile’ again 😀
    #341567
    quickwash
    Hi stryder,
    This is to show you that if you continue to post on a previous thread it will jump back to the top 😀
    ‘That’s the way to do it’ :violent: (sort of simular to punch and judy 😉 )
    good luck
    quickwash :plug:
