Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › zwd4270w wont fill
- This topic has 9 replies, 3 voices, and was last updated 13 years, 2 months ago by
delta01.
January 22, 2013 at 11:12 am #73692
delta01
Participanthi this machine wont fill then aborts fairly soon can anyone help please
thanks johnJanuary 22, 2013 at 12:50 pm #388443Martin
ParticipantRe: zwd4270w wont fill
Megger the heater?
January 22, 2013 at 1:47 pm #388444delta01
thanks v much Martin will try that
January 22, 2013 at 8:19 pm #388445delta01
hi heater fine whole machine reads good on megohms i checked usual things pump carbons inlet valves etc any other possibilities ?
January 22, 2013 at 8:40 pm #388446Seamy
Martin wrote:Megger the heater?
As Martin says megger the heater, the dryer heater, if its low it will cause problems.
Not sure of the machine as theres no 4270, but I presume its a ZWD14270W.
The dryer heaters are notorious for causing erronious faults & causing wash programme to stall.
Isolate appliance from power.
After noting wiring positions of cables to dryer element, disconnect them & insulate them.
Try wash programme to see if it runs normally, if it does & goes faulty when cables connected to dryer element you’ve found the fault.January 24, 2013 at 4:39 pm #388447delta01
thanks Seamey will try that, just remembered i had a similar fault some years ago that was the dryer heater, although i would have expected it to show up on the general megohms test thanks again …John
January 24, 2013 at 4:53 pm #388448Martin
delta01 wrote:although i would have expected it to show up on the general megohms test thanks again
It should indeed show up in a general Megger test at the plugtop, only needs to be less than 40 meg.
January 25, 2013 at 1:48 pm #388449delta01
hi thanks again guys it was the dryer heater, will it work ok just as a washer with heater disconnected ?
thanks John
January 25, 2013 at 8:50 pm #388450Seamy
It will work as a washer without the dryer heater connected as far as I remember. But now that you’ve sussed it why not stick in a dryer heater & completely repair it.
January 25, 2013 at 11:58 pm #388451delta01
i might but i rent washers out and have a surplus o cwd’s and its a sealed tub so i don’t want to spend money on a heater in case the bearings fail
