ZWF1431s fault code E80 Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › ZWF1431s fault code E80 This topic has 2 replies, 2 voices, and was last updated 18 years, 11 months ago by ed101. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts May 27, 2007 at 9:08 am #27666 ed101Participant Help! The washing machine has packed up and displays the fault code E80. Prod no 91452120200 Thanks for your help May 27, 2007 at 12:59 pm #215124 Penguin45Participant Re: ZWF1431s fault code E80 Moved to Washing Machine Support…….. E80 is a general code relating to the recirculation pump. Either the pump or wiring has failed, or the computer thinks it isn’t there. Power off, if investigating. Regards, Penguin45. May 27, 2007 at 2:30 pm #215125 ed101Participant Re: ZWF1431s fault code E80 Penguin45 – Many thanks for your help. Popped the back off the washer, found the pump and found a wire off. Looks like the near by wiring loom has knocked it off. Secured wire with insulation tape. Thanks again. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
