ZWF1621 Not spinning
  • #68844
    Profyaffle
    91479132002 Customer reports that the machine is not spinning properly. Carried out diagnostic and received E41 relating to the door lock. Is this a phantom fault as I’ve changed the door interlock and the customer is still saying nothing has changed. Heater ok, motor ok. PCB? Or do I need to look closer at the heater circuit? Ideas? Technical Data please?
    #372953
    Re: ZWF1621 Not spinning
    Moved to correct forum. 😉
    #372954
    Allsorts
    Not spinning correctly in which way?
    Could be faulty Tacho
