Re: ZWG5125 leaking
Thanks for that seamy, I’ll double check that but iirc that was all clear.
It’s a bit like the hotpoint dispenser that leaks out the side and you have to change the dispenser top.
The reason I asked I’m sure a long time ago I changed just the y connector to solve this problem something to do with the jets of water hitting each other to direct into the conditioner compartment, but I might be wrong.
Blow it I’ll change both.
Thank’s again :tup:
