ZWH7148P only washes
  • #80966
    neilbow
    Hi folks I have come across the machine, at first it would only pump out whatever program you put it on and did not count down. Then disconnected the appliance from the power supply and did a full electrical insulation test. then the machine did fill and wash (and I thought I was on to a winner) but there was no countdown or heating action it just sat there washing. I suspect the control module. Any thoughts anybody. Regards Neil
    #414981
    Seamy
    Re: ZWH7148P only washes
    Pressure switch not reset perhaps if its pumping continuously as you describe.
    Look at the pressure chamber, drain pump, filter in drum, outlet hose etc for blockages.
    Did you check the heater for continuity?
    Did you check last error code?
