Al Clarke
ParticipantOriginal suggestion was to try swapping the electrode leads. This now makes sense, if in fact the electrodes are effectively their own sensors. I suspect swapping electrodes instead of live inputs would have had same effect.
Al Clarke
ParticipantOK I’ve swapped it to L2 yellow, L1 orange. And it worked. Well done gents, I appreciate the advice.
Now my gut feeling is the problem is likely to return, as it worked fine when the new spark gen was installed as per wiring diagram.
So watch this space….
.. but thanks again, hopefully that’s all there is to it.Al
Al Clarke
ParticipantYou say electrode wires – do you mean the live inputs to the spark gen, or the electrode outputs?
Al Clarke
ParticipantI’ve got L1 yellow and L2 orange as per the diagram. And diagram shows them both coming through the clock so shouldn’t make any difference. But I’ll try swapping …
Al Clarke
ParticipantYes – stops clicking when all oven knobs off. Don’t have to switch off at wall.
Problem occurs whichever oven I light first. Lighting other one on stops sparking. Turning either oven off starts the other sparking again.Al Clarke
ParticipantThis is the one I bought:
https://www.ebay.co.uk/itm/283500228284
Same as this one as recommended by the v helpful man on this site, unless I am mistaken:
https://shop.ukwhitegoods.co.uk/a048030-ignition-generatoredit: yes switched off at controls, not a
t wall!
