Re: Washing Cycle Problem with Hotpoint WMFUG742
Dave, up until today the water was being pumped out although the amount coming out of the outside waste pipe was very slow. Anyway, today I tried another wash and half way through all the lights started to flash and code F05 came up, and I noticed that the machine still had water in it. Checked the code, and said could be pressure switch, pump problems or a blockage.
Shoved a cable up the outside waste pipe, and only a bit of gunge came out, however I switched the machine back on and set it to pump out and spin. Like Niagra Falls outside, haven’t seen it pump out like that for a while. Pump out and spin completed successfully, so hoping that was the problem. Do you think it’s worth getting machine out and checking the flexi hose for any more debris?
Thanks for your help.
