Alan_C
ParticipantRe: WIL 143S
– I guess 1980’s TVs are a bit different! Ok, My plan of action is as follows:
– Find the water level sensor thingy and test its switching ability as well as the wiring loom to it and the controller PCB with continuity multimeter.
– So a thermistor in this case IS what i would call the thermostat – it tells the CPU when the water in the drum has reached the correct temperature – test continuity from this to the controller board.
– If all checks ok, then replace the controller board and I have a new Washing machine?!!
😆Thanks again!
Alan.
Alan_C
Thanks for the replies by the way – Chatty Man? never heard of the guy ❓
A thermistor problem is something different to the temp sensor problem right?
From my days as a kid disassembling old TV’s, a thermistor is a safety cutout device often found on PCBs near high voltage PSU components – they blow when things get hot so fires dont start. Am i on the right path? If the thermistors you refer to are those capacitor looking things near the bigger resistors/240v electrolytic cap and inductor, replacing the board would solve that too?
Or am I way off?
I cant seem to abandon the idea of a fix. Its a possible £50 to fix my existing machine or over £150 for a cheapy new one as I’m a bid skint at the moment (or just a waste of £50 and then ANOTHER £150+?) Is there any hope?
Thanks for any more replies! 😀 !
