Andrew_H
  • in reply to: LG Door Seals Part Number Codes/Structure #482339
    Andrew_H
    Good Evening,
    Four months on and I am now sorted, dream scenario. Back in May I left an email alert on ebay for the seal ‘LG 4986ER4986’ and lo and behold last weekend a notification popped up in my inbox. New seal, the seller bought it some years ago for their machine, a very close model number to mine, but never got round to fitting it, by implication they have moved on. Opening bid was £10 + (2.70pp) and all week nobody bid against me! Arrived today and indeed brand new and still in its original packet.
    Happy bunny.
    Bye for now, Andy
    in reply to: LG Door Seals Part Number Codes/Structure #482337
    Andrew_H
    electrofix wrote:short answer dont know. have got rubbers for machines that fit ok but the lip on the inside is different so it catches the drum. what it boils down to is its a lottery. Unless you have the design spec you will never know and also if there was one that would fit it would be listed somewhere
    Good Afternoon Dave,
    Thanks anyway, I will keep pursuing this as best I can. I will bear in mind ‘catching the drum’.
    Andy
    in reply to: LG Door Seals Part Number Codes/Structure #482335
    Andrew_H
    electrofix wrote:your does seem to be not available but there are other close part no the may well have a chance but we have no way of knowing
    your part no is as you say 4986ER1003B but there is a gasket part no ends 1003A . that is still available but is listed by my supplier as door seal without tube. which means the pipe in the door gasket could not be fitted. It may be possible, if its the same size to blank off the pipe and remove power to the pump that feeds it provided the rest of the rubber fits. But again its a try it and see job and if it does not your left with a rubber you cant use
    Thank you for replying.
    Yes, my mind turned to the 1003A, blanking off the redundant drain hole is no problem and I thing I would be up to adding a circulation pipe at the top. The big question is the overall diameters front and back. How do I find this?
    I came across a list of models that also use my obsolete 4986ER1003B door seal, 33 machines in total. That’s a lot of disappointed LG customers when they find their machines are scrap, a bit naughty of LG.
    I think the list came from LG which made me think there might be a LG portal just for professionals with more technical resource, what I need. Is this true?
    I have been searching LG seals and found one that looks identical, it has a not needed drain hole at the bottom but seems to come conveniently blanked off. Other parts of the moulding are the same, just this overall size question again. Do LG machines tend to follow a staple diet of standard sizes for tub and door apertures or are they all different?
    https://www.ebay.co.uk/itm/303938643235?hash=item46c427a523:g:at0AAOSwZ1VgYdbk
    Any answers to my questions appreciated, thanks.
    Andy
    in reply to: LG Door Seals Part Number Codes/Structure #482332
    Andrew_H
    Good Evening Don,
    Thank you for taking the time to reply, appreciated.
    I am surprised you found some available I have spent hours looking. When I search ebay with ‘LG 4986ER1003B’ it returns ‘0 results …’ but under ‘results matching..’ lots of near seals such as 4986ER1003A top of the list but this has a drain pipe at the bottom and no circulation pipe at the top. Is it allowed for you to post direct link to one you have found?
    On part numbers I am used to dealing with car VW part numbers which are highly structured but many LG seal part numbers start 4986 so beginning to wonder if 4986 means seal. As the one I recieved in error was larger I was wondering if the letter after the E is related to drum size (mine is 8kg). I really want to know how to tell the drum size from the part number then I will have a choice, I am not too fussed about a circulation pipe at the top, I am confident I have enough plumbing experience to add one. It is the overall diameter of seal front and back that I see as critical and in an ideal world buried in the part number.
    Cheers.
    Andy
