Andy B
Viewing 1 post (of 1 total)
  • in reply to: Panasonic NA-140VG3 need headphones !!! #471470
    Andy B
    electrofix wrote:there will be 2 pumps
    one for circulate, one for drain
    i would find and open the circulate one and check for debris first
    Thanks Dave. I didn’t realise there was two pumps. Any idea where the re-circulation pump is located and how to access it ? The drain pump i guess is the one connected to the front panel drain plug, but not sure where the re-circulation pump would be. This by definition must be the cause of the issue and all other noise issue bearing assemblies are definitely OK.
    Many thanks for the help so far.
    Andy B
