Andy_Surf
  • in reply to: Rosieres Bocuse Single Oven Thermostat #267822
    Andy_Surf
    Re: Rosieres Bocuse Single Oven Thermostat
    Hi Bryan,
    Finally got the hob off (don’t ask), I’ve removed the thermostat from the back of the oven switch and the thermocouple out of the oven. Any way of testing this now ? Should I get no current when I heat the thermocpouple up.
    Cheers
    Andy
    Details on unit (oven is rated at 2.8kw)
    16(2.5)
    250/380
    ~0.5K/mn
    T150
    50_310ÂșC
    in reply to: Rosieres Bocuse Single Oven Thermostat #267821
    Andy_Surf
    Hi Bryan,
    Can’t even find a picture of this model to show you, but trust me – if there were any more removable screws or bolts, I’d have found them. The hob plate is a kind of “tanked” design with no screws in it at all. It has one electric hotplate and 3 gas burners, it was mostly available as a 1200mm unit with one extra large gas burner/griddle, but I have the 600mm unit.
    Cheers.
    Andy
    in reply to: Rosieres Bocuse Single Oven Thermostat #267819
    Andy_Surf
    Thanks Bryan – I thought it might be this part but my model no. wasn’t listed – too old ?
    Any experience of dismantling these babies – as I said – there must be a knack because I’ve removed every visible screw, front and rear, and there doesn’t seem to be a way to get at the control – I’m hoping I don’t have to cut off any pop rivets !
    Many thanks
    Andy
