Bansi Dave
ParticipantRe: Bosch Aqua Star smv65m00 GB/35 – E15 Error
Hi Martin,
I really appreciate your thoughts.The air vent O ring on the side of the tank – little confused on that, The inner chamber where dishes are kept it has the plastic cap which allows little water to enter. The O Ring keeping the gaps sealed appears normal (it was quite hard to undo to be honest)
The O rings at the end of the hoses at the bottom were dry.
Can you suggest how I can diagnose the following (hopefully without taking the base pan off)
“Other leaks could be from the welded seam of the s/steel tub especially in the corners.
The sump gasket perished = Not sure what this is (I understand the Sump area where water collects and the pump drains the water)And, the main circulating pump a possibility. – Is this different to below?
The small round pump connected to the Sump, i removed and added PTFE tape and reconnected to ensure there is no leaks…..the area below the Pump is dry.
Obviously without you inspecting in person, Would you suggest that I proceed ahead with the Heat Exchanger replacement. Costs £72.
https://shop.ukwhitegoods.co.uk/0068031 … -exchangerKind regards
Bansi -
