beer-merlijn
Viewing 1 post (of 1 total)
  • in reply to: Indesit IWDC6125 – drain issue #436269
    beer-merlijn
    Re: Indesit IWDC6125 – drain issue
    Hi iadom,
    Thank you for your explanation regarding the drain issue on the Indesit IWDC6125.
    When you are saying: “disconnect and re-connect the pressure switch hose”, I read it as disconnect and re-connect the pressure hose from the pressure switch, (as opposed to disconnecting it from the drum.) Also, I have unplugged the machine while doing this.
    Update: I just saw this, from your hand: “If the lower end of the pressure hose is blocked then you are in trouble, the pressure hose is attached to the pressure chamber which on these machines is part of the totally sealed outer drum.”
    The lights still come up flashing after the pump has pumped one litre out of the machine.
    Any suggestions?
    Kind regards,
    Beer-Merlijn
