Re: Belling fan oven keeps cutting out
Thanks for the comment, have looked (with no fingers close!) at the switch as I select different setting and it does flash when getting to the setting that (or when) it works at.
Have resisted the temptation to take the oven completely out because of the weight but I guess that is the next step (WITH THE POWER OFF).
Okay, took the switch off and the last contact was blackened and the the flexible contact that the switch moves had flipped up so was only making contact by accident rather than design, took the connection apart, pushed the switch contact back in, reconnected the contact firmly and everything works 😀
In the long term will need a switch but for the moment it works and it is a simple task to change the switch.
