Big-Ashy
ParticipantRe: AEG Lavatherm 56600 / 91601409901- No heat?
Martin114 wrote:Hi Adrian, I think the resistors you mention are in fact microtemp thermal fuses.
π Thanks Martin. I am not familiar with this type of fuse and they look very much like a resistor but are open circuit with no evidence of heat damage or blow marks.
Adrian πBig-Ashy
π― Yer, big initial outlay of test equipment and specialist tools in my game, but been doing it that long now, I don`t even think about the cost over the years π
These are defo resisitors and not the NTC type you refer to, but are that small and thin in diameter (approx 20mm long and 4mm diameter) I can`t make out the resistance marked on them in Ohms.
Both resistors are defo open circuit, I`ll give Serviceforce a bell in the morn for a price on a new heater assembly, unless you can recommend another supplier elsewhere. β
Many thanks for your advice and asistance Andy.
Cheers,
Adrian. π
Big-Ashy
Hi Andy,
My apologies, those readings are in Ohms and not Megohms. π―
Now you have said that there are only two elements, I now understand how they are wired. As mentioned previously, there are four elements stacked vertically and wired in series, but the white cable wired to the middle of the four is the common neutral to make the two wired in series either side to give the 1100 & 1400 Watt heaters.
Heater one β Brown & White β 38.2 Ohms.
Heater two β Blue & White β 46.4 Ohms.From what you have mentioned above, these two resistance values donβt seem to far away and as I mentioned previously the neutral is wired through a small resistor which is open circuit and the coil circuit (Black & Grey) is also wired through a similar resistor which again is open circuit but with no obvious signs of βblownβ damage. β
Are these resistors essential or can they be wired out of circuit. β
Hope this clarifies the situation, but please feel free to ask for any further information. π
FYI, I am a commercial refrigeration and A/C Service and Installation Engineer with 25 years experience, sound like a right old git now donβt I? π
Big-Ashy
Many thanks for your swift response!
Since your post, I have removed the heater assembly from the machine and opened up the galvanized casing to expose the elements etc.
I use a Fluke 110 Multimeter for testing and the 5 pin jack plug was disconnected throughout.
When the casing was opened up, it revealed that there were four elements in total stacked on top of each other and wired in series. The five cables wired to the assembly can be described as below:-
Brown/Blue β Phase and neutral wired to the either end of the four elements wired in series.
Grey/Black β Klixon coil circuit
White β Wired to the middle of the four elements to create a presumed star point affair?Resistance measured as below:-
Brown/Blue β 82.9 Meg ohms
White/Blue β 46.3 Meg ohms
White/Brown β 37.3 Meg ohmsWhilst having the assembly in pieces, I also noticed that there are two small resistors in circuit. One is in the klixon coil circuit and one is wired in series with the white cable before it connects to the middle section of the four elements.
Both of these are open circuit and have no resistance at all when tested, could these be blown and at fault?
After this I reassembled the heater, I did a live test on the 5 pin jack plug. The black cable (coil circuit) had 240V on but was not present at the klixon due to the resistor which is open circuit. Could this be preventing the coil circuit being complete and energizing the relay back at the pcb to power the heater?
Apologies for rattling on a bit, but I have to do the same in my field of work and appreciate as much info as possible.
Many thanks, Adrian.
