Re: Whirlpool AKP951 top oven not heating properly
clivejameson wrote:First thing to check is the lower element…switch the top oven on and hold your hand on the base inside. You should notice a temperature rise within a minute or so and not be able to hold your hand there comfortably after a couple of minutes….
Also, does the thermostat light go out at any time when you have it set to 200 and above?
Hi, I’ve just tested what you’ve suggested, bottom gets hot enough not to touch after about 5-8 mins, I can instantly feel heat coming down from the top. The thermostat light turned off but after opening the oven to check the temp it came back on again, so that’s recognising the drop in temp.
I left it on for 16 mins at 200c & it just managed to go slightly over 100c
