bob- I can break it!
Viewing 1 post (of 1 total)
  • in reply to: Mistral- compressor not starting #177277
    Re: Mistral- compressor not starting
    Hi Alf
    Cheers for reply- I’ve gone through and checked all the connections- all seem fine. I’m stumpted. Couple of questions-
    The thermal overload cutouts both measure 0K at 22C- is this correct? (by these I mean the red blocks mounted on the evaporator coils) Should they be shorted (0K) or open (infinity K)? I’m guessing short and they ‘pop’ when overheated and go open.
    Also- I’ve just remembered I accidentaly knocked a wire out when replacing the thermistor. I put it back in the logical place but I’m wondering if I’m wrong. The wire that came loose was the brown wire coming from one of the thermal fuses. I put it back into the white connector next to the thermistors. The only other spare slot is in the white connector on the right where the live goes to the fan and heater. Anyone know where it should be or ideally have any pictures (really wish I’d taken some!)
    Cheers 😛
