Bristol_Red
ParticipantnomadPaul wrote:the plastic container is filled with stones/gravel/pebbles. It is used as a counterbalance to counteract the added weight for when the door is open and a full bottom tray is pulled out. If installed under a worktop where there is no movement i.e the dishwasher is tight to a worktop and can’t tip forwards, the weighted container isn’t required as much .
Ahh that makes sense!
Many thanks for the quick reply 😀
Cheers Andy
Bristol_Red
ParticipantRe: Zanussi ZSF4123S not heating up… PCB?
Sorry guys false alarm all working fine now !
Thanks for all your help much appreciated 😀
Great Forum… :tup:
Cheers Andy
Bristol_Red
OK found that the PCB had a dry joint exactly the same as the guy in the link I was posted had with his, but soldering didn’t cure it. So a new PCB has just been fitted but still no hot water….
Any further suggestions please guys? Cheers….
Bristol_Red
iadom wrote:
Bristol_Red wrote:
Can anyone please point me inthe right direction to start and where the PCB is located, in the door?
http://tinyurl.com/yps7u9 😉Thanks for the quick response!
I will have a look over the weekend, cheers 😀
