cable_n
  • cable_n
    Re: Bosch Logixx S9V11B – PLEASE HELP, got used- sound-no wa
    None flowed out. I think we even had it completely on its side when we were moving.
    cable_n
    Re: Bosch Logixx S9V11B – yes it seems to be flooded
    An electrician was out at the flat today and he checked the solenoid in the back. The solenoid is not getting any power to let water into the dishwasher.
    Unscrewing the cover for (I think) the salt canister, it is full to the top with water. How do I get the water to drain if it is full and not draining. How do I untrip the flood protection?
    cable_n
    Re: Bosch Logixx Typ S9V11B does not run with water
    Anyone??? Please Help…
    cable_n
    Thanks for the reply Penguin!
    I haven’t actually used the dishwasher before. I bought it recently used. The owner said it sat for a year and I had him set it up and run a cycle…but I wasn’t there so I’m not sure it was working correctly.
    Water came out of it while I was moving it to the new flat.
    As far as the Typ number it is hard to read because it is written close to the edge of the metal.
    If it helps here are more things written on it:
    Bosch Logixx auto option (on front)
    Maxx freedom perform (on top)
    Typ S9V11B
    E Nr. SGS69A0GB/13
    Is there something more I should check to see if it has drained properly?
