carlos fandango
Viewing 1 post (of 1 total)
  • in reply to: Smeg DWD612C leaking from water softener unit #302756
    carlos fandango
    Re: Smeg DWD612C leaking from water softener unit
    Thanks Penguin45 for your swift response.
    I understand the part No. you’ve supplied relates to the gasket in the water softner cap.
    I am enquiring about what if anything goes under the water softner ring P/No. 763890467 (the part I’ve replaced as original was split).
    I also wanted to know what way up the softner ring went. I take it from your post the grooved side is up.
    Sorry if I didn’t make myself clearer in the original post.
    Carlos Fandango
