Re: Liebherr 7802 freezer – issue with temp sensor?
Ah, yes. Sorry. Correct details are:
Type = SWNess 2900 Index 20a/001
Service Number = 9985228-01
Appliance number = 23.474.549.4
So it seems like it might actually be the refrigeration unit itself as originally, the wine cooler said 5 degrees and
the freezer -18 but both had no refrigeration. I switched the wine cooler off and as I did so the display went to 20 degrees which I believe was the actual temperature. On the freezer there is a ‘superfrost’ option. I tried that but it
turned straight off. I then turned the freezer off.
About 15 minutes later I turned both back on and the read wine cooler 21 degrees and freezer had no display just ‘–‘. I’ve just tried them again and they read the same.
Hope this gives some more information.
Thanks for any help you can provide.
