Chris Salomon
  • in reply to: Diplomat/Smeg ADP8221 Sticking on drain sequence #250886
    Chris Salomon
    Re: Diplomat/Smeg ADP8221 Sticking on drain sequence
    I think you have hit the nail on the head Penguin, tried it with the anti-flood temporarily disabled and it works fine. Maybe faulty switch or a pressure problem in the pipe? I have cleaned out all the plastic unit to the side, that was quite mucky.
    in reply to: Diplomat/Smeg ADP8221 Sticking on drain sequence #250885
    Chris Salomon
    Penguin, I can guarantee the undertray hasn’t flooded, mainly because it is still leaning against the wall! I haven’t refitted it yet as I couldn’t make out how it was held in place, I think I must have broken the clips on one side on removal. Would leaving it off cause the same symptoms?
    in reply to: Diplomat/Smeg ADP8221 Sticking on drain sequence #250883
    Chris Salomon
    Thanks for that Karv. The heater is still working though, everything is, the water fills, circulates, heats, even the detergent dispenser opens, its just when it empties it keeps on emptying!
