Thanks for that man. Is the Bosch ok to work on though? Can you remove the front panel, or does it have a large removable rear panel? This complete piece of sh** I have, could’ve been worked on, if you put it on a stand, where you could get access to the underneath, to remove the motor, the weight on the lower part of the drum etc. I just couldn’t be bothered for a £150 piece of crap. I just wondered if the Bosch was actually easier to work on. If it isn’t I think I’m going to get a cheap Beko, and bin it when it fails…
