Colin_Fed_Up
ParticipantRe: Bosch Exxcel Not draining
Well it looks like it is fixed. Done another 4 washes and it is still going. Thanks guys for the help
Colin_Fed_Up
Well I unplugged the reed switch and let it do a cycle and got an E14 error as your would expect. I then plugged it back in and ran another cycle and it worked correctly. I have now done another 5 washes and it is still pumping correctly. I am amazed that it is still working. Going to put it all back together and see if it still pumps correctly but looking good so far. Will let you know what happens
Colin_Fed_Up
I just read that the reed switch is a flow sensor. It is next to the output so i assume it is checking flow rates which is why the pump starts and stops? How do you change it? I cant see any screws or tabs to get it out.
Colin_Fed_Up
Is the default open or closed for the switch? I can unplug it or short it to test
Colin_Fed_Up
I have just had a look at that. Isnt that for the water temp in the heat exchanger? Everything works fine except the water wont pump out.
Colin_Fed_Up
Is that the little glass thing about a 1/3 way up on the heat exchanger (the large plastic tank on the left side)?
